plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Unread July 17th, 2019, 11:31 AM   #1
Nortech
Ireland
Nortech is offline
Writing out to Universal Robot dashboard socket 29999 through TCP/IP from AB Complogi
Hi All,
Has anyone written commands to a Universal robot dashboard through TCP/IP socket from an Allen Bradley Compact logix PLC?
I'm using the Modbus TCP Master Sample Application example from the rockwell website and seem to be getting connected momentarily before the connection is dropped.
Has anybody got any experience with this?
Unread July 17th, 2019, 11:42 AM   #2
Contr_Conn
United States
Contr_Conn is offline
Contr_Conn's Avatar
Did you try to get a wireshark capture to see who is closing connection?
Unread July 17th, 2019, 12:49 PM   #3
Nortech
Ireland
Nortech is offline
Hi Contr_Conn,
No. I didn't but following through the Rockwell sample code, I can see that the PLC closes the connection due to no response from the robot despite the Initial MSG blocks seemingly creating and connecting to the socket successfully. Have you done this before?
Unread July 17th, 2019, 12:58 PM   #4
Nortech
Ireland
Nortech is offline
https://www.rockwellautomation.com/s...pLinking=false
This is the link to the sample code download (Its the second one (for compactlogix))
Unread July 17th, 2019, 01:15 PM   #5
Contr_Conn
United States
Contr_Conn's Avatar
Before you dig into the working code you should see what is on the wire.
Then it will give you a direction.
You may need to replace your slave device with some Modbus simulator and get it working this way.
There is also Quick Start technote that has exact example.
Unread July 17th, 2019, 01:50 PM   #6
Nortech
Ireland
Nortech is offline
I am not sure how to do this.
I can communicate with the robot socket from my PC using SocketTest v 3.0.0
How do I check whats on the wire?
Unread July 17th, 2019, 02:31 PM   #7
Contr_Conn
United States
Contr_Conn's Avatar
https://lmgtfy.com/?q=wireshark&s=g
https://rockwellautomation.custhelp....il/a_id/576972
Unread July 18th, 2019, 12:34 AM   #8
Geoff White
Australia
Geoff White is offline
Try using a socket comms test program like hercules test utiiity. That way you can eliminate problems at the other end too.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Mitsubishi PLC R04CPU Socket TCP/IP comm via build in Ethernet port example programs ALMAR LIVE PLC Questions And Answers 1 December 5th, 2017 05:00 PM
Universal Robot with AB PLC rootcon LIVE PLC Questions And Answers 2 March 24th, 2015 08:48 AM
┐FANUC Robot R-30iB communication with AB Micro 850? alonsok LIVE PLC Questions And Answers 0 December 26th, 2014 08:18 PM
