1769-L16ER-BB1B Embedded Digital Output Endurance
zacslade
Oct 2014
Phoenix, AZ
84
Hi All,
I have an application where I am supposed to make this light flash under certain conditions, using an embedded digital output on an Allen Bradley 1769-L16ER-BB1B.
I want to know how many times these internal, embedded relays can toggle in their lifetime before they fail. If it's more than, say, 30 million, then I suppose I don't have anything to worry about. If it's less than, maybe, 5 or 6 million, then that's a problem for me.
If operating conditions matter, they are not in a location with any significant shock/vibe. The temperature and humidity are controlled in a dry, human-comfortable range.
Can anyone point me to where this information is recorded? I haven't been able to find it in the manual. (Maybe I just keep missing it?)
Thanks in advance!
When operated within their specified current limit, the solid-state outputs on a PLC controller (like this one) have an very long lifetime because they don't have the physical wear of an electromechanical relay.
Power transistors and solid-state relays do heat up and cool down as they cycle, so it's very important that they be run within their rated current capacity.
You'll find estimates that a typical solid state output can cycle on and off for between 2 million and 50 million hours.
A PLC output that's just running an LED indicator lamp can be expected to run indefinitely. The LED itself should be good for about 50,000 hours of on-time.
The outputs on that model PLC are transistors so the number of cycles are almost limitless. The easiest way to destroy a transistor is by having it switch a load that is too high. So you may want to put a interposing relay in the circuit. A lot will depend on the light you want to switch and it’s current draw.
I once used real relay outputs for something similar, they lasted about 3 months. The operator panel had 50+ push-pull maintained illuminated red buttons for control; Center maintained was 'Auto", Push momentary was E-Stop, pull was maintained "Manual Override". Lights were only supposed to be flashing when an operator put a part of the system in manual override, letting him know that it was operating that way because there were potentially serious sequencing consequences. I got called out 3 months later, the operator had all of them pulled out and was wearing sunglasses to avoid getting a headache. He believed he could manually control it better than my program was controlling it, albeit ignoring all of the safety interlocks I had. The relay contacts had welded on about 1/2 of the outputs.
The outputs built into the CLX processor however are all solid state, shouldn't be a problem.
looking for the the MAC address for this PLC, I count find it in the front or at any part of the PLC itself. connected to the PLC by USB, showing...
1,760
Hey Everyone, I'm using studio 5000 version 33.12 The plc firmware is 33.012 I have this plc model: Compactlogix 5370 1769-L16ER-BB1B and when I...
17
5,583
Hello, I'm gonna try to make this as clear as possible. For a project, we have 3 Unitronics PLC's controlling each a machine. The company that...
3,414
I plan on using a CompactLogix 1769-L16ER-BB1B , to control 3) PowerFlex 40 with a 22-COMM-E communication card in them. I took notice that in the...
22
17,951
I'm still very much a novice, so if you're kind enough to offer help, bear it in mind and take nothing for granted! I've just powered-up a brand...
3,901
