Thanks for the info. Can you tell me what language the program is in (LD, SCL, ST, etc.). The pic you attached makes no sense to me. I exported the project to S7 in WinSPS, and then migrated it to TIA v16. I also exported the symbols file and ran the CSV file through a translator so all the tags are English. But the 36 FC blocks look similar to the image you posted. All it has is the tags and their addresses. Where is the logic? What is the purpose of the adding the semi colon?
Would it be possible to go online using PLCSIM? Wouldn't i need to configure the hardware first?
