Profibus Testing
jt5405
Dec 2007
Cincinnati, Ohio
Hi all,
We are running 7 Profibus networks with a Siemens 315-2DP controller, up to 14 stations and an HMI on each network. We are currently using a Siemens BT200 for network testing. 20+ year old technology, which requires every connector to be unplugged for testing. Most of the newer testing protocols allow for live testing. I am wondering if anyone can recommend a product they have been happy with. My boss is actually willing to spend money for this, so I would like to find the best value for the money spent . Look forward to your thoughts!
:geek::geek:
Actually, I'd use POE (Profitrace Over Ethernet), built inside ProCenTech's COMBricks product.
Very awesome, and it remains online all the time, and doesn't need a laptop or dongle.
Cool product! I don't have much use of continous analysis like that though because most installations we do/work with have several fiber converters. Guess I'd need one of those for every profibus-copper-segment?
Thanks for the responses. I think we will go with the Profitrace Mercury model as it will also work with Industrial Ethernet networks, so we can cover more equipment. I appreciate the feedback!
Hi, I was noticing that Profibus connectors have 2 ports on them that can house 2 separate cables. Can I use 2 cables with Profibus signals...
134
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
47
I am trying to implement a profibus network and am a newbie in the automation and communication industry. what are the components required for the...
82
Hi, I am using TIA Portal V18. I have imported a (v5.7) SIMATIC manager project via device proxy. I have created a HMI project (TP700) in TIA...
281
Hi Folks, I am new to the S7-300 and the whole Profibus communication. And I just wonder that can you connect a S7-300 module to a Beckhoff Bus...
301
