RSLogix 5000 instruction copy/paste left instead of right?
Derp-Dee-Drrr
Jan 2015
Phoenix, AZ
This is a real simple interface problem.
Typically when I'm developing in ladder I will Ctrl+C an instruction and Ctrl+V, the new instruction will appear to the right.
Well, I think I mashed my keyboard or something cause now pastes always appear to the left. Similarly, if I copy/paste a rung, it appears above instead of below.
I'm thinking I mistakenly hit a keyboard shortcut but nothing like this seems to be described anywhere. I might go crazy.
CTRL-I toggles between insert and append modes.
I have version 20 and 30 open right now and it works in both.
There is also an indicator/selector in the bottom right of the program window that changes from APP to INS and back.
Triple D
My only thought after looking at all possibilities in help and properties would be to try another keyboard or install an external one on your laptop and see what happens. Hope this helps.
Hey guys, thanks for taking the time to look into my question. I'm building a system to monitor several other systems for faults and one of the...
17
4,630
I"m trying to average an array of DINT's called FIFO_ARRAY. It has 1000 elements in it. Here is what I have entered into the AVE instruction...
4,715
Hello Please Help, I want to use a FSC instruction that will scan 20 DINT arrays. If the arrays are greater than 1000 display the value. How do I...
1,755
Hi There, When i did FRD instruction in SLC 500 its working, when i try to simulate in RSLogix 5000 same way as i did in SLC 500 which is not...
2,711
Hi there, I am trying to create an Add=On Instruction to help me manage some alarm conditions in my application. My AOI has one Boolean output...
2,539
