RSView32 Project: Primary Communication Driver: None Loaded
DrewSanders
Jul 2018
Renton, WA
This is a total novice question... hopefully I can describe clearly.
We have a Windows 7 machine with an Allen Bradley 1784-PKTX Card installed. We have the device drivers installed and all looks good in Windows Device Manager.
We have an existing RSView32 project that we are trying to run on this system (it currently runs fine on another virtually identical machine running windows XP). When I go into the project and look under System - Channel. Channel 1 is set for DH+ but the Primary Communications Driver is "none loaded" and the drop-down has no driver loaded. This should have an AB_KT-1driver available to select but does not.... what I am not clear on, is how do you get the AB_KT-1 driver to appear here?
Thanks for your help!
Guessing....
RSLinks on the XP loads the 32 bit drivers that are available, but RSLinks on the W7 is a 64 bit and it does load 'all drivers' only the ones that are compatible with 32 bit OS's
This is a 32-bit install of Win7. After digging around I did realize that to get the driver loaded I need to do that from RSLinx Classic... and it appears we do that in RSLinx Communications - Configure Drivers But when we launch RSLinx Classic we do not get a program interface, it just starts the service. What am I missing here?
Hey guys, A new client I'm working with has an older system, running RSView32 with AB SLCs and Logix500. I want to copy the existing project and...
5,026
FT View Studio Ver 8.0.0. RSView32 project is about 2007 vintage. From help file: To import an HMI project to a local station application:In...
10,472
Is it possible to import trend data into an existing project? I have previous trend data and would like to import it into the current project.
1,995
Hi all, I installed new computer with rsview32 7.4, rslynx, RSLogix500, RStrendx v3.44, and run project, project working fine, but not show...
2,173
hi i have made changes to a project in rsview32 but i would like to try it before i put it on the hmi, is there a way to run it off a laptop? i...
2,200
