Omron Upgrade
Mrslipmat
Mar 2009
Inside a cabinet somewhere....
199
Gents
This one is for any Omron Guru,s out there, I,m more of a Siemens man myself, I have a processor which looking at it has pretty much run out of memory, it,s at the point where you can,t go online to do any mods as it does,nt have any processing power left to do so !! The CPU in question is a CQM1H-CPU51.
1) is it possible to upgrade this unit without having to replace all the i/o cards ?
2) if the above is possible, what would the best route be CPU wise ?
3) Would the current program be able to be downloaded without conversion ?
Many thanks for any forthcomming help
Regards
John
Your only real option would be to replace the CQM1H-CPU51 with a CQM1H-CPU61. The CPU51 has 7.2K of program capacity, the CPU61 has 15.2K, a bit better than double.
The CQM1(H) I/O is unique to that series.
Program will directly transfer, you would just need to update the CPU setting in the software.
Hope this will help.
Hello, I am not that familiar with the omron plc line but have made program modifications to a CJ2M. I have a machine that needed more hardware...
2,463
Does anyone else have an issue downloading from their Automatic updater? I typically get around 1MB/sec this is running around 70kb/sec. Is...
3,311
Equipment manufacturer sent an upgraded program file, but I cannot open it with my version of CX-Programmer (Version 6.11). It says I have to...
2,813
just renewed our contract to get the latest version of cxone. The version of cx programmer that I use, which is version 6.3 We have dozens of...
2,747
Hi There. I have PC to get few tags from PLC into C# windows forms application. What is the best and fastest way? I could not find Omron in...
164
