Cognex said they did not have anything after taking a sample of the product that they thought would be reliable and had a banner rep who said the same thing. I experimented with a Banner Array sensor on the bench just trying to see the clear material without it being on the fabric, and results not very good. Actually the sensor was a banner fiber optic array type sensor, just vibration on the fiber cables for some reason made the output change almost a half of a millamp. The resolution is 1mm.
Not much luck, ordered a array sensor from automation direct just to experiment with it. Hoping to just detect the width of the clear material as it comes out of the extruder nozzle and with a analog output going back into a allen bradley plc, scale it to know the width. Very straight forward to measure and scale but the problem is getting something to see the clear material consistent enough to put on a high speed production machine.
