plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old August 23rd, 2017, 09:32 AM   #1
RMore
United States
RMore is offline
Micro 820 - 2080-TC2 thermocouple filtering
What's the most effective filter to use for the thermocouple wiring on the input to the 2080-TC2 plugin module on a Micro800 based design?
Old August 24th, 2017, 02:03 PM   #2
RMore
United States
RMore is offline
Additional information: The 2080-TC2 module is intermittently faulting a few times a day, potentially due to a solenoid switching. Most of the time the fault only results in a bad reading or two, however, on a few occasions it has crashed the program resulting in error code F0A1h). I assume that it is noise from one of the solenoids making it's way to the TC module, either thru the power supply or the unshielded TC cable, however, I am not yet able to get it to fail on the bench. Has anyone experienced faults on the TC Module and what was the ultimate fix?
Old August 24th, 2017, 02:16 PM   #3
Dirt
Sweden
Dirt is offline
https://www.youtube.com/watch?v=8KhqIbwcOhg
http://www.mosaic-industries.com/emb...e-noise-filter
Old August 24th, 2017, 03:20 PM   #4
RMore
United States
RMore is offline
Dirt, Thanks for the replay. Useful information ,however I do not have control over the input circuit design for the module and Rockwell does not provide a schematic. Also, the module does not provide a ground terminal. I was able to determine that the input impedance is roughly 340K with the negative input tied to ground thru a 10K impedance.
Old August 24th, 2017, 04:24 PM   #5
damica1
United States
damica1 is offline
Set your data refresh rate to 50 Hz this will help.
__________________
David M. Camp
Unlocking the power of IOT in Oil & Gas!
Old August 28th, 2017, 10:36 AM   #6
RMore
United States
RMore is offline
Currently my update rate is 16.7Hz I can change it to 50Hz. Can you explain what factors determine the optimum update rate?
Old August 28th, 2017, 01:39 PM   #7
damica1
United States
damica1 is offline
According to the manual 16.7 Hz refresh rate will result in an accuracy of + or - 1% (Do you really need that tight of results?)
A 50Hz refresh rate will result in a + or - 3% accuracy (This forgives a lot of noise/spikes/Etc..)
You might just try and make sure it works for your needs.
__________________
David M. Camp
Old October 9th, 2019, 08:53 AM   #8
RMore
United States
RMore is offline
What about ferrites?
Has anyone had any success using ferrites on thermocouple wires to reduce noise spikes getting into the inputs? What about adding a cap or MOV across the input?
Old October 9th, 2019, 01:25 PM   #9
Mickey
United States
Mickey is offline
Mickey's Avatar
Quote:
Surge protection on all inductive loads? Will help if this is your problem.
__________________
Mickey
If you want happiness for an hour-take a nap. If you want happiness for a day-go fishing. If you want happiness for a month-getmarried. If you want happiness for a year-inherit a fortune. If you want happiness for a lifetime-help someone else.
----- Chinese Proverb
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Micrologix 1100 or micro 820 papejo LIVE PLC Questions And Answers 4 July 20th, 2017 10:32 AM
AB Micro 820 re-connecting B777 LIVE PLC Questions And Answers 1 February 3rd, 2017 06:56 AM
Micro 820 with hmi cdnrookie LIVE PLC Questions And Answers 6 November 11th, 2016 07:28 PM
CCW Micro 820 Greater Than function dginbuffalo LIVE PLC Questions And Answers 8 May 14th, 2016 12:27 PM
Micro 820 Messaging SLJackson LIVE PLC Questions And Answers 1 July 3rd, 2015 04:13 PM
