comunication between Barcode scanner and PLC
angi
Jan 2010
us
361
Hi guys
I got a question about Barcode scanner and PLC:
my SLC 5/04 will send some strings to a PC by using Channel 0, and a Barcode scanner also hook up with the PC.
is that possible to send the barcode information to my PLC, if could, how to do it?
Angi,
Using a communications protocol (RS-232, Devicenet, Ethernet, or some other) that is compatible with both your bar code scanner and your PLC, connect a cable between the two. Then write PLC ladder rungs to read the bar code data into PLC memory.
thanks Lancie
there is a cable between PLC and PC, and I also could send string from PLC to PC, and how to send my barcode information from PC to PLC using the same cable?
First, we would have to know what the cable is communicating (what communications protocol it is using).
Do you have any information about this cable. Is it a shielded cable, or a twisted pair?
One way to transfer data from a PC to a SLC 5/04 PLC is with a MOV command. The MOV in Rung 001 uses indirect addressing to determine the memory location of the data being moved from the PC to the PLC.
Is There currently data going from the PC to the PLC? Is There data only going from the PLC to the PC? If you only have data in one direction this is an easy problem to fix if it is going in both directions. It will make it a little tougher for you.
First look and see if data is going both directions.
Jeff,Lancie
there is data from PLC to PC using Channel0 of PLC and USB port of PC.
Is it possible to transfer data form PC to PLC using the same cable.
I do not know the protocol of the scanner, just normal Motoroal barcode scanner.
Jeff,Lancie
Can't see a reason there wouldn't be. The communication link between the PLC and PC should be a two way street.
You'll have to program or configure the PC to send the barcode data to the PLC when it receives it from the scanner. Then you'll have to program the PLC to receive the message and interpret it.
Those are vague, general instructions, but you've given a rather vague description of the application. We'd really need to know what software is running on the PC that is receiving data from the PLC and what protocol it's using to get any more specific.
the barcode information just could be displayed on Notepad, and the strings from PLC also could displayed on Notepad, how to send the barcode infor on the notepad to PLC?
Thnaks
I do not know the protocol of the scanner, just normal Motorola barcode scanner.
The Motorola barcode scanner will have hardware and software to send data directly to the SLC 5/04. You need to download a copy of the Motorola User Manual and find out what method it uses to communicate with the PLC.
I could send barcode data from Barcode Scanner to PLC, but I do not know how to make the data transfer to PLC through PC by same cable.
Angi,
You probably won't be able to do a thrid-party transfer, without more information. Unless the PC is running some program that allows passing data from the barcode scanner through PC to PLC, then you are out of luck.
It is more likely that it is possible to do it the other way: Barcode scanner to PLC to PC. But then you do have to have complete information on all 3 pieces of equipment in order to figure out how to do that.
hallo guy's, I have problem in comunication between PLC and SCADA. :shoot: I connected the plc with the scada and codesys due the keep server...
1,469
Hi everybody , I have to wonder if it is possible to exchange data and how. Someone knows where I can find material about? any help is...
1,729
well i have a issue in my job i need to comunicate one escanner dataman 8100 and one plc wago by codesys but i can't. i put the diferent protocols...
970
Hi I want perform the comunication (ethernet) between ML 1400 (IP: 192.168.1.11)and Red Lion HMI G304k200 (IP: 192.168.1.20). I wrote the...
5,238
hi guys I just got a problem here, I set up the comunication between HMI and PLC, I could ping PLC from HMI, but they did not connect with each...
2,866
