1756-L7SP Safety Task watchdog expired.
MAHAJAN247
Apr 2015
Nashik
Hi
I have a gaurd logix system with L73S and safety partner L7SP.
1756-L73S 1756-L7SP faulted with major Error Type 14 Code 01 and after clearing the fault, when controller put in run mode, again faulted with error type 14 code 07.
I have checked technote 46434 and 68112, and checked the points given in both technotes. but could not found a reason in the program which can cause the watchdog time expire.
The program has contineus task and safety task. safety task has logic in it.
system is installed and running from 8 months, this is the first occurence of this type of fault.
Can you suggest what can cause safety task watchdog expired.
260
Hi, I have two quick questions: 1- Could I use 1756-IA16/A with TTL inputs? Sourcing (PNP)? Sinking (NPN)? Either one? 2- What does /A in the part...
149
Hi all, installed on chassis A17 an A/I from Allen-Bradley , problem is what ever I do , all channels are sticked on value 39.9 and cannot change...
141
Hi, Is it possible to for an RIO with Flex 5000 series module, e.g. 5094-AEN2TR, to communicate with an 1756-L72E processor.
90
please using the usb can i assign any ip address that i want ?
150
