Scadapack 350 to control ABB VFD
95ee32069
Jun 2005
I am trying to use an Scadapack 350 to control an ABB ACS550 VFD through the modbus RTU but have limited knowledge of Scadapack. I am ok with the VFD and its wiring and modbus registers. I have the telepace software and get it communicating with my computer but have only program an Allen Bradley plc before. What i need is to be able to read and write to the VFD register to control and read infomation from it. Anyone one here familar with Scadapack?
I'm not familar with your VFD, but if you want to read/write over a Modbus connection you want to start by reading about the "MSTR" function "Master Message" in the SCADAPack. See link below for a sample program and the programming manual if you don't have it.
http://www.controlmicrosystems.com/resources-2/software-downloads/programming-samples/telepace11/
http://www.controlmicrosystems.com/media/product-literature/software/telepace/manual/TelePACE%5F3%2D40A%5FUser%5Fand%5FReference%5FManual.zip
Thanks Mickey that is a good manual and seems to be the perfect start. Anyway i try opening that LAD files with telepace evaluation but it failed to open giving a message "not backward compatible". Do you have a screen shot of this ladder logic file?
Sorry, I don't have the software anymore. Its been a few years sense I worked with a SCADAPack. Hopefully someone else will jump in here.
I've got 16-bit data at address 40200 on a Schneider Scapack 350. I can grab the data over Modbus TCP using Kepware at IP 172.16.1.100. When I...
2,488
I am programming a SCADAPack 350 with Telepace Studio. I want to know if the logic in running the first scan and if the program is running...
1,247
Hi! I've got a customer that has several SCADApacks at remote sites and I need to make changes in their cellular network system. I have the .pia...
1,875
Hi guys, I'm working on a well pump that is supposed to use a PID loop to maintain system pressure through changing pump speed. I'm using a...
2,218
ok fella's i have a question. i am trying to get data from a scadapack 350 in the field and use it on my wonderware. i can get data from it but it...
1,779
