ControlLogix - Logix 5582ES Safety CPU. Any special edition of RS Logix 5000 needed ?
Rob S.
Sep 2008
Maryland
739
Good Morning ,
We have some new machinery coming in with a ControlLogix 5582ES Safety CPU . I would like to update our software before the equipment arrives .
Is there any special edition of RS Logix 5000 needed for Rockwell Automation Safety Processors ?
Thanks again for your help ,
As discussed in that linked thread, the Safety editor is required to work on GuardLogix controllers. It's included in the big Enterprise license, or sold separately like the language editors (ST, FBD, etc). So that addresses the "edition" of Studio 5000 Logix Designer.
The other matter is the version of Studio 5000 Logix Designer to support the hardware and firmware. The 1785-L82ES is one of the newest and most powerful GuardLogix controllers, and you must have Studio 5000 Logix Designer version 31 to support it.
A quick reference for the GuardLogix controller generations and the appropriate versions of Studio 5000 is in RA Knowledgebase article 476521
Hello, I have two 16 point input cards and 1 16 point output card showing module faulted on my IO tree in Logix Designer. The fault code is...
199
Hello, My associate and I are trying to sync up two ControlLogix racks (7-slot chassis) with identical modules. We are able to see the secondary...
162
Trying to setup a message read via Ethernet. I have the path setup as 1, 1, 2, 192.168.66.10 I get an error code 1, ext err 315. I am beating...
222
I have a redundant ControlLogix being set up. This program reads a value from a remote site which happens to be SLC PLC. Rockwell mentions SLC...
89
Hello, I have a ControlLogix redundant controller being set up. The program reads a value from a remote site which hosts a SLC PLC. Rockwell...
67
