Team,
Project details: Make Kepware monitor the PLC connection and send an email if plc is offline for x amount of time.
Seems simple enough, however, I have limited experience with kepware, short of changing the IP address to a PLC that is already set up in kepware.
When they sent me out for training a while back, I was given a full version of KepserverEX V6, this is a fully functional set up with all applications, same as what we use in house. This version that I have requires a restart after a couple of hours, so it cant be used in a production environment. This does give me the option to poke around and not mess up the main system.
Things I have figured out:
I can add a device.
I can generate the tag database.
I can see said tags in the OPC client.
I am kind of stuck here, I am not able to see the tag value, but I am not getting any errors. Getting frustrated is half my issues, not having something to reference to is the other half.
I do have some "training" items that has gotten me this far, but I am looking for some more documentation and or tutorials on how to progress through the alarm and event set up.
Once I can get this working in my test environment, I will feel more comfortable with adding the alarm function to the live environment.
I have a 5370 test PLC that just has a few timers running, so I have the hardware and the kepware software, issues are at the meat level..
Thank you in advance,
Gad
I can add a device.
Gad
