Step7 PDM8.1 PA Routing
LiamC
Nov 2009
Manchester
I will try and keep this as brief as possible..........we have "inherited" a project consisting of four master PLC's, lots of DP and PA devices. All devices can be written to and read in the PLC software without issue. But when we use PDM to modify PA instrument parameters, we can only access certain networks :- we get the message "Device not found, Communication attempt Failed, there is no usable route to the Target Device"
All CPU's 6ES7 414-2XK05-0AB0 firmware 5.3
Each CPU is using CP443-1, 6GK7 443-5DX04-0XE0 firmware 6.4, which gives two additional ports for DP.
We are then using IM 153-2 DP-PA couplers 6ES7 153-2-BA82-0XB0.
PLC1 - DP1 - PA1 network -Good, DP1 - PA3 network - Good
DP2 - PA2 - can't find devices DP2 - PA4 - Can't find devices
PLC 3 DP1 -PA1 - can't find devices, DP2 PA2 can't find devices
PLC 4 - same as PLC1 but DP1 Bad, DP2 Good,
PLC5 - both PA networks Good
Recompiled and downloaded Netpro and Hardware numerous times.
All connections done over ethernet from control room, but tried connecting directly onto PLC MPI/DP port - same results as above.
Have re-installed PDM, my colleague also has the same issue.
Is it possible to configure the DP-PA couplers locally ?? from what i have read they are a "dumb" device.
Any ideas welcome !!
Thanks for the reply Gary - unfortunately i had already visited this thread several times, will have to keep chipping away at this issue. Have a good weekend !
This is the first time I am working with Simatic Manager Step7 as I started my siemens journey with TIA which is pretty easy and do a lot of stuff...
134
When you download a DB, the values get overwritten by what is in the "actual" column in offline DB. Does this happen at the start of the PLC...
141
Hello Inside a FB, I´m trying to transfer a string from a DB to a IN_OUT var that was define as a UDT. The problem is that i can´t determine the...
127
Hi all, I am trying to convert RSLogix 5000 program to Step7. I need to bit shift left my array of double integers for tracking the product on...
519
I have a word in some DB which I want to load to AR1 and use as a pointer. In order to do this I need to write L DBxy.DBW xy SLD 3 LAR1 I...
533
