Powerflex 525 - What would be the best way to reverse in RS Logix 5000
Aug 2016
Virginia
343
Good Evening ,
What would be the best way to reverse a motor using a Powerflex 525 drive in RS Logix 5000 ? The drive is running in one direction , but would like to reverse it, I'm using Ethernet and a CompactLogix . I took notice that the Forward and Reverse in the the outputs for forward and reverse are 0 , but it is still running . I took notice that the input from the drives for "Actual" direction is 1 . Would I force a 1 in the Forward or Reverse ?
Thanks for your help ,
put a 1 in ??:O.Reverse and it will go in reverse
to get it to go forward again you will need to take the 1 out of ??:O.Reverse and put a 1 into ??:O.Forward.
Alan
?? = your tagname
230
Im trying to teach a couple of labs on VFDs at a community college. We have some motor control trainers with P525s and 3 phase motors from...
236
New to vfds. I put in parameters. IP, but I get ethernet flashing and link solid. What did I do wrong?
470
Are the N files in the 525 the same as the 40p for ethernet? (E-Comm card) I have used 40P with Micrologix 1400 Messaging but don't see the N...
225
Hey all, I am currently working on a depalletizer for a customer and we are doing a hoist upgrade. This is a SLC500 processor and the drives are...
294
