Mitsubishi GXW3 - Error SlibFbFile
swedeleaner
Dec 2013
Göteborg
150
So, the Red Diamond is at it again...(y)
Error LED lights up, with Minor Error 3401, Operation Error.
But Error Jump doesn´t even point me to where it happens.
Since it´s a minor error, the CPU is still running, but can´t send it to a customer like this..
The support doesn´t even seem to know where to look.
Anyone here that have experienced this?
Sounds like a programming error to me.
Can you reproduce the error or is it spurious/random?
You may have to try and narrow it down unfortunately
Regards
Daniel
I can "reproduce" it by resetting it, wait about 4-5 minutes and then triggered again.
Obviously it doesn´t occur every scan cycle, and since I just run it on my office, no peripherals to modify any inputs.
It does occur in the simulator as well, but it takes longer between each error occuring. I don´t use any pointers besides a PID-controller, which is working.
I have an earlier backup from about 6 days ago which runs without any hassle.
Have started comparing my FB:s that have changed since then, but no obvious faults. No useful warnings or compiler info..
So, a random error occuring once every 5-20 minutes...
The error contains stepnumber, but it seems that you are unable to look at the compiled code that is actually running... But it occurs at the exact same spot every time. Something like Sequence Step nr 295, FB 6.
Sounds possibly like an overflow? Are you using any array pointers?
What about FLOATs?...are you using any in your code?
If it was me....id remove half my tasks; and try narrowing it down.
Regards
Daniel.
hi all, I'm wondering if anyone has ever converted an Allen Bradley AOI to a Mitsubishi Function block. I's hard to find libraries from...
130
Hello, I have a Mitsubishi FX3G 14M PLC and a E615 HMI from Mitsubishi/Beijer. I'm using GXWorks 2 to do the programming and I have no problem...
161
Hello! If someone can help me with the following problem. I can't change the phone number. Do I really need the interface (AL-232CAB - Programming...
71
how to communicate FactoryTalk Optix and Mitsubishi Q Series. I want to know the details of that
84
HOW to communicate with OPTIX and Mitsubishi's Q Series PLC?? PLEASE HELP ME
97
