RS 500: Copy Register values from One program to another?
theColonel26
Feb 2014
West Michigan
785
I have a .RSS file that has had a lot of the logic modified but I want to import all of the set points and recipes as they currently are in the PLC. Is there a way I can export just the values associated with register addresses and then re-import them into the new version?
If you have two instances of RSLogix 500 open at the same time, you can drag a data file from one to the other and it will bring the values with it. There is another method that has come up on the forum, but I will have to hunt for it.
I think you can select/highlight multiple values and copy/paste them too.
Thanks Guys I will give them both a try
IIRC, when you "drop" the file into the target location, the cursor needs to be on top of an existing file of the same type but can be a different file number. Be careful not to replace the wrong file. The software will warn you about replacing it even if it is the same file number.
I am using a SLC500 is it possible to copy an F register into 2 N registers ?? I am looking for to transfer the bit image of an F Reg in 2 N...
3,118
All, We are looking into the best ways to protect IP in PLC/SCADA code and the latest offerings included with TIA portal seem much better than...
3,921
Hey all: Is there an option in Logix 500 to copy a contact instead of move it while editing off line? When you are online, if you drag a contact...
1,378
Hey All, I have: COP Source #L[N60:4]:[N60:2] Dest #L30:0 Length 4 When I compile the project, I get: WARNING: File number doesn't point to...
1,692
Hey, I'm looking for easy and fast way to copy data files from different data tables. for example: All F8 (255 elements) to F9 (same size of 255...
2,093
