Panelview 700
You likely mean PanelView Plus 700, I don't think a PaneView 700 is a thing.
To "connect", would suggest that you just need to upload/download. You would use FactoryTalk Transfer Utility to do that. Though that is not absolutely necessary, you could transfer an application via USB or CompactFlash/SD (depending on the era).
If you need to edit/create/program the application that is running on your PanelView Plus, you would need FactoryTalk View Studio ME.
My Panelview plus 700 HMI stopped working and I replaced it with a new one. Moved the sd card from the previously installed panel to this one and...
16
985
Good day all! I need to make some modifications to a Panelview program. I uploaded it from the unit. Tried to use the Application mgr. to...
1,088
Hi All. I am working on my home automation system again and i am looking at setting up a panelview. Currently running an AB Compactlogix...
836
Hi. I'm working on a plant that has a panelview plus 700. Problem is that from time to time, the alarm list shows an old false alarm instead of...
2,709
