Tia Portal Changing device from s7-1500 to s7-1200
thewalkerist
May 2021
Izmir
178
Hello everyone, i had a recent project that i was working on before. Now since i didnt have any PLC's before i used to practice and chose the device as s7-1500. But now i got a plc of my own and its a s7-1200. I wanted to change it but it seems i cant do that. Is there way for me to do that?
No, there is no way to change from a 1500 to a 1200 PLC. The best you can do is drag and drop the function blocks and DB's from one to another. The 1200 also has some data types that the 1500 supports that the 1200 doesn't.
Also, the 1200 will not support STL.
So if you have any FBs or FCs with STL in the 1500 you'll need to convert them before copying.
1200 doesn't support Graph either.
Dear god, why would you use STL in 1500 though?
I wouldn't if I was putting a new project in one.
However, I've used it plenty of times when migrating a project from S7. Or copying an FC or FB that has had years of testing in working machinery. No point in re inventing the wheel. Personally I don't mind STL it does the job quite well.
Hi, What I thought should be relatively simple process turned into a bit of an issue at a client today. I'm not as experienced using Siemens /...
7,100
Im trying to create a level indicator for water Tank i have used the ADD function while the pump is on and level increasing everything works...
20
My PLC (S7-1200 with CPU-1212C) has now been delivered to customer site. They've asked me to do some updates to the software. I can do that on my...
21
327
Does anyone know why the connection interface is greyed out and says why I can only use Teleservice instead of the other options like PN/IE? I am...
44
Hi guys I after a bit of advice on Tia portal graphics, I would like to add a conveyor belt graphic to a hmi and the conveyor in the basic...
130
