Tim Ganz
I have a motor with encoder that comes in as a 4-20 analog input to a 1766-IF8 module. When the motor is running I need to look at the encoder value and make sure it’s changing when the motor is moving and that it’s changing enough.
What is the best instructions or way to monitor this value and it’s rate of change and set an alarm if it’s not moving at all or not changing at an acceptable rate.
Looking through the instruction set I am just not coming up with any good ideas on how to do this and I am starting to think that I am overthinking it
