RE: FactoryTalk View Tag Browser Datatype - UNRECOGNIZED
rtgibson
May 2012
Barnsley
44
Hi All
I have a new install of FactoryTalk View SE 12 with the May 2022 patch rollup installed.
I have a little test app that can't see all of the 'program' tags in the PLC (an L30ER) - I've done loads of these so I know to click 'Refresh All Folders' etc.....but when I create a test HMI tag and browse through the online connection I can only see some of the tags and ALL tags say UNRECOGNIZED for the data type.
What have I done/not done ???
Russ
The plot thickens....
Well I decided I'd try V13 instead of V12 just to see if something amazing happened...it didn't.
But in V13 it is showing the datatype of the tags when I browse through them it just doesn't show all of the tags. I've done what it says in the tech note regarding some recent DCOM issues but that hasn't solved it.
I can never get v13 to browse tags created previously or test screen properly, I have to either copy the tag name from the PLC and paste into FT or use the offline file.
Can't fathom if its FTv13 or studio 5k v34 that causes the issue.
Some success....kind of.
Well....it turns out that all of the tags that wouldn't show up in the tag browser are 'Alias' tags. Don't know why there's an issue it's worked in all the other FactoryTalk SCADA's I've done - last one was V12 (only a month or so ago).
So I've had to do something quick and dirty to get by....created a bunch more standard BOOL tags and branched round the alias bit - at least I can see those new ones in the SCADA now.
Anyway - thanks for your input guys.
I have a FactoryTalk View Se project, Is it possible to export Direct Reference tags to edit in a CSV file or Excel? I know I can export HMI...
288
Hi All, I'm trying to look into if it's possible to get FactoryTalk SE to build a process log report, recording various tag values at a poll rate...
577
We are cutting over a PLC5 to ControlLogix and we ran into some issues with the HMI (FTView v10, Network Distributed). We found that after...
948
Hi All, Does anyone know that how to monitor tag value during the client file is running? I don't want to create button with animation to find...
1,450
Hello, we have a project using FTView SE 10 (Network Distributed). We configured PLC and HMI in an existing application, and the communication...
1,075
