EsLogix 5000 error - control logix 5550 lader
ntldr123
Sep 2020
usa
Hello,
I was trying to create new module in I/O Configuration and I get the "Fatal Application Error"
Below is my plc setup if I need to try to connect and do auto configure
1756-PA72 psu
1756-L1/A cpu ser: A F/W: 7 REV:11
1756-IF16A
1756-IF16A
Blank
1756-IA16/A
Blank
blank
1756-CNB/E
Blank
1756-OW16I
1756-A10 backplain
This is while not connected to the plc. Any idea what I'm doing wrong. I'm used to rslogix 500.
See below the steps that I followed
1.
attachment.php
2.
attachment.php
3.
attachment.php
4.
attachment.php
The Test file
http://www.plcs.net/downloads/index...ame=Default_Test.rar&directory=Allen_Bradley&
Thank you for your time
David
In my experience working with ControlLogix PLCs, Fatal Errors are kind of normal, sadly. They won't necessarily happen every day but they will happen, and seemingly at random.
I am not sure what has caused your Fatal Error but just try again and if it keeps happening, try rebooting. If it still keeps happening I would start again - do a new upload from the PLC if you have it or otherwise create a new file and try again.
Then if it still keeps happening, contact Rockwell Tech Support. There may be something with these older versions and PLCs that you are using.
You're using a VERY old version of RSLogix (v11). It was outdated when I first started using Logix 5000 in 2009...
That being said, I have worked with that version in the past but it was on Windows XP. The fatal error message mentions "Unrecognized OS", which could be the problem. What OS are you using?
I opened up my old XP virtual machine and was able to open your test file and add an -IF16 module to it with no issues.
What exactly are you trying to ultimately accomplish? Your file mentions a 1756-L55, which supports up to v16. Is this a test rig you want to use to learn how to use?
If you have not already done this, run Logix5000 as an administrator and disable UAC in Windows. Doing both of those things have significantly reduced my instances of errors.
I have Windows 10 x64
I executed Logix5000 as an administrator and disable UAC in Windows. I also change the comparability ....with no luck
Hello everyone, I'm new here, I hope someone can help me. I've been trying to install EDS files to my Studio 5000 with the EDS tool installer but...
86
Hello all, Hope you all are having a good weekend. Can someone share me an opinion to which software should i get. We have around 5-6...
148
Hi Everyone, I am facing an issue while installing the STUDIO 5000 in my windows 10 PC. During installation I am getting an error that " Error...
166
I am connecting to a remote device. When attempting to upload I receive an error that states: Error: Auto_Functions: The Import was aborted due...
175
Hi all. Never really noticed, but I started double checking operands in the CPT instruction. I found if I have the expression N7[37,1] - N7[35,1]...
134
