Omron CQM1H-61CPU and NT631C HMI How to connect them to a PC?
shaydzmi
Nov 2022
Casablanca
17
I have an Omron PLC (CQM1H-61CPU) connected to an Omron HMI (NT631C).
In order to connect a PC to them, I want to know:
1- Is the cable used to connect them (between PLC & HMI) suitable for this purpose (going online)?
2- Can I use an RS232 to USB converter cable which has a male SUB D9?
3- Can I use a null modem serial cable, which I use with AB SLC5/03?
4- Can I buy a generic RS232 cable (Male / Female)?
5- If any of the above wont work, I need a wiring diagram to make one.
Thanks.
Cable diagram is attached.
You cannot use the cable between the PLC and HMI for transfer.
You should be able to use a USB to RS232 adapter.
Some work, some do not. FTDI chipset units tend to work.
Null modem and straight thru cable will not work.
Good Luck,
gtsuport
Hi Everyone, I have a customer that needs a CQM1H (CPU51) replaced. They purchased the processor new-old-stock from a source they found online...
335
I have an Omron CQM1H-CPU21 and a NS8-TV00B-V1, I have followed the manufacturer's spec on how to set this up and all I got is the HMI is trying...
867
Hello maybe someone can help me, I have omron CQM1H PLC with CLK21 (Controller link module) and SCB41 (Serial module connected with NMB CSD-891B...
536
Hello, i have a omron plc with cqm1h cpu, and is protected by um read password i need any program to crack it lik xtal, plc backup tool v6 with...
1,057
Hi, I'm looking into a way I can share data between an old Omron CQM1H-CPU51 PLC and an S7 1200. I've done a similar thing with an old Siemens...
5,610
