I_Automation
A VFD can be designed to put out close to double the input voltage.
I have controls that are 240V and include 240 In 480 Out VFDs.
The DC buss is charged with each side of the AC phase going to one side. An AC voltage of 480 is actually +480 for half a cycle then -480 the other half. Using input diodes the buss could (almost) be charged to 960V theoretically (with no load being used) Commonly the buss would be at least 600V.
If your VFD does occasionally put out a higher voltage that is not motor regen, then it may have bad IGBT transistors.
