cheapest 4-20 mA analog input card
automan said:
Signals will be read into a 12 bit word.
I love the discussions that go on here sometimes.
Seriously, do you already have a PLC? Programming software?
Are you going to be using this analog value to control anything?
Do you need a PLC input card, or would a stand-alone multi-meter suffice? How about a PC interface card?
What are you asking, and what do you want?
I think you will find that you can answer your own question.
I want to read some analog values and log them.I'll implement the logger program by Visual Basic.There is no PLC and no CONTROL
look at pioco in england they make an A/D converter and is connected to a serial port
works great and can be used in any program even a laptop.
I never try to buy the "cheapest" anything - life is too short to put up with the BS that almost always results.
I try to buy the least expensive item that I know will provide a high level of quality and reliability and not cause me problems or headaches. That is what I refer to as the best value. Sometimes, but not often, this is also the cheapest item. Sometimes, but not often, this is the most expensive item. Usually it is somewhere in between.
..that you know of, other than the 1783-ETAP A? I am trying to setup a device-level ring testing setup environment for training that I may need...
1,480
I have an application that needs 20 inputs and 20 outputs with only 10 XNOR and 10 NAND blocks. I could do it with relays, but this could end up...
5,169
Hello, What would be the cheapest PLC running codesys I would be able to get my hands on? I like to expand my mind and I started out as an AB guy...
30
13,462
I want to fill a hole in my skillset by picking up AB PLC programming. Although I'm at a very advanced level with GE PLCs (I mean GE-IP, no I...
3,337
I almost have a complete, basic setup for a shop/learning fixture. I've got a used CPU317-2 DP, a G120C, and some purple hose. I'd like to add...
20
5,380
