SLC 5/04 controllogix communication
pct_jimmy
Dec 2006
Shady Spring, WV
61
Hello all,
I was wonering in any of you could help me out. We have a machine that runs on controllogix platform and are looking to add a few things to control transfer chains and such on a machine that run on an SLC 5/04. I am new to controllogix and wanted to know if there was any way to get these to to talk to each other.Basically have an input in the controllogix point to an output in the slc.
you could add an 1756-DHRIO card in the control logix rack and put it on DH+ network if there is a spare slot.
then messages between the two is easy done
cheers
myles
how close are the two PLC's? if you want it done on the cheap and they are close enough, you could maybe link them using the serial port on them.
i have no experience of this and not sure if it is possible, just a thought! hopefully someone with experience will chime in and advise!
cheers
myles
Hi Guys I am new on here, I have about three years PLC programming experience and I am trying to do something that I haven't tried before...
4,437
On the application i'm working on, i have to communicate an Allen-Bradley SLC500 with a Controllogix by DF1 without using any additional module...
3,950
I have a redundant ControlLogix being set up. This program reads a value from a remote site which happens to be SLC PLC. Rockwell mentions SLC...
89
Hello, I have a ControlLogix redundant controller being set up. The program reads a value from a remote site which hosts a SLC PLC. Rockwell...
67
Hi all, if I remember correctly, there is some way in a ControlLogix (or CompactLogix) where you can sort of map tags into SLC addressing format...
1,131
