Siemens Technological CPU Blocks
roxtech
Mar 2008
Township Lahore
198
I have cross cutter example for Siemens 315T CPU. This example have function blocks FB530, FB531, FB532 and FB534. my question is 'Can I use this function blocks with technological CPU 314C?
or VIPA CPU 314C ST.
My second question is 'How can I add PLCopen Blocks in Siemens Library.o_O
No. A 300T actually has two processors in it
A motion control and standard one. If you look at the plc open blocks you will notice they are the same size (or very small). This is because a "job" is passed to the motion control CPU with these blocks.
Anyway the answer is No
Dear All,
Ok. I understand. but in Siemens Easy Motion control we can get motion control solution. Then why can we not get rotary cutter solution by 314C CPU.
best Regards.
Because Easy Motion blocks do not support Cam profiles.
Cams are required for cross cutter application
Have you looked at the dcc S120 cross cutter application note?
Hello JRW,
Thanks for detail answer. Yes Cam is necessary for new concept of cross cutter application. But in old machines a single motor run both nip/draw roll and cutter roll and size adjust by P.I.V gear box between nip/draw roll and cutter for size adjustment. Then why we cannot be use electronic gearing function of positioning system in place off P.I.V gear box?
Best Regards,
I have established an online connection to a machine using an S314 processor. I am using an mpi connector and simatic manager. The online...
62
Hi everyone, i have a Siemens S7-300 Cpu 314C-2 DP with several cards of i/o and servos my laptop has TIA version 16 and 17 loaded and...
132
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
214
Good morning fellow sea captains and wizards, I am being asked to do the above and obtain 4 values from each slave, I know about the MRX and MWX...
27
562
Hi everyone, I am an omron plc tec , lately I came across a siemens s7 200 cn plc . Can someone help me regarding the software required and...
26
498
