Connecting Siemens PLC CPU (315 DP 2) to TP 270 Via Zlinx Radio Modem (Wireless)
libbysen
Aug 2009
Al wakra
Dear All,
I would like to do the following project in a crane which runs on Siemens PLC S7 300 CPU 315. Its connected to a TP 270 (Touch panel). All i need to do is to connect the TP 270 to a remote area (ie) 5 Kms away by connecting it to the PLC via a radio modem (Zlinx) Range is 14 miles.
Following are the Deatils of the hardware i have:-
1. Siemens S7 300 PLC with 315 Dp2 Cpu. (MPI-Interface)
2. Siemens TP 270 (MPI / RS 485 interface)
3. Zlinx Radio Modem with 14 miles range,whichsupports RS-485.
Could anyone please explain me what i am lacking. Cause i tried connecting in all ways according to the manual but i could not commumnicate. Waiting for a good response.
thank you.
Libbysen
Hi All, I have a closed loop stepper motor (Nanotec make), https://en.nanotec.com/products/2512-pd4-e601l42-e-65-4. This uses MODBUS TCP for...
3,853
Ok, I want to download my S7 program into my CPU 319-3PN/DP. The problem is I can't even get my PC to talk to the PLC. My ethernet cable is...
2,868
Hello chaps. Have a small problem. How do I go about connecting to a PLC that has been set up as in the attached diagram? I have no problems...
2,556
As a part of the final year Bachelor Thesis project I and two others are involved with, I have been tasked with setting up an HMI/SCADA system...
8,657
We have the following scenario where we need a Controllogix PLC to be able to read data from Siemens PLCs on two separate networks. Controllogix...
5,767
