Network repeat relay
blackbird307
Jun 2015
Winnipeg
59
Hey all
I am looking for a network based relay that will energize relays in the event an input is energized at the other end of a fiber line. I guess a repeat relay of some sort. Ill need to find one that will transmit and receive 15 inputs and actuate 15 relays on the other end. I am aware this can be done with PLCs etc, but I am looking for a simple solution application specific.
Haven't been able to find one, maybe im using the wrong terminology. Tons of junk on amazon. Preferably something commercial and CSA rated.
Thanks again!
You can get an Idec Smart relay on each end to do this and have one a modbus tcp master and the other a slave.
FL1F is the part number. And they are cheap and CSA
Check out Control by Web, their Web Relays do exactly what you describe.
I have several deployed doing this same task.
I’ve also used their hardware as stand alone control devices and as Modbus/TCP remote I/O.
Tom
We are having an issue with some servers, with "Teamed NICs" is we plug one cable leg of the team into one switch and the other to another...
53
Good morning fellow sea captains and wizards, I am being asked to do the above and obtain 4 values from each slave, I know about the MRX and MWX...
27
567
Hi, I am working on a project, where I face a issue with respected to Network Dropout. The PLC is connected to a 16 port unmanaged switch, where...
180
Hi Everyone, Currently we have three plants running with Controllogix PLCs (L72, L73, L74). In each of these plants we have 2 FTView SE...
53
Hi, I am facing an error inside Omron Network Configurator. I have 2 PLC communicate each other using ethernet cable, send signal using Network...
116
