JaxGTO
Customer has a lot of old PV600 I have been converting over to PVP7 using the adapter plate.
Now we have a PV550 (2711-K5A2). Has anyone had luck with the PVP7 (2711P-B7C22A9P) fitting in the same cutout?
The PV550 is 144mm (5.67") X 243mm (9.57") and the PVP7 is 142mm (5.59") X 237mm (9.33"), just 2mm narrower and 6mm shorter.
I think it will fit fine with the overlap of the screen, just curious if anyone else got it to fit okay.
I want to test fit one but the 550 is completely falling apart. I'm afraid if I touch it, it will quit altogether.
