Factory Talk View - Popup block the click
saeqsae
Jul 2019
Concepcion
45
Hi all, i need to block the click when a popup is opened.
The click should be only in the popup and block any click outside the popup.
There is any configuration to do that? Or Visual Basics Code?
Thanks in Advanced
Can you just make the pop-up fill the entire screen? Or do they need to see information that's not on the pop-up screen?
Gonna try the capture cursor, i saw it once but didn't know the function.
About the fill the entire screen. I can do that, at least the background can set it to "Transparent" to see the Traffic lights i have on the background. Thanks both, guys
where is there an option to set the background to transparent? Because I attempted to do that the other day, called AB tech line and was even told by them it wasnt possible. This is with FTVS ME.
JZerb, i didn't know that. I though it was possible. Should try another way to do that. Need some help ):
I typically just do a pop up on the entire screen. But I’ve never had a scenario where the operators needed to see what was behind they pop up for the short period of time the pop up was popped up. If that’s a requirement for you the long way to do it would be to make the pop up window and include all of the things that would still be visible on your normal screen, that way the pop up window “looks” like it a pop up with a transparent background but in reality it’s not. Other option is to look into using the Information Messages in FTVS to accomplish what you’re looking to do.
Looks like a lot of work to do, considering all the traffic lights i should replicate, by the way this scenario was just a question from my client, i gonna tell to him is cannot be done for the moment. Thanks for your answers.
Should be easy to replicate it all, just copy and paste. Or duplicate the screen and delete the stuff you don't need and then add the pop-up stuff.
Not that tough. See below.
Hi all, Attached below is an example of what is happening to our existing SCADA. It seems after patching some Rockwell Software that I thought...
314
The client has an application that when communication between the PLC and the Factory Talk VIEW supervisory fails, the object in the supervisory...
279
Hello all, I am looking for a way to have a user get logged out after an X amount of time because to default so that user privilages are no...
566
Hello everybody. I was wondering if there is a way in FTVIEW Studio to close ) view after x min without interaction . My issue is the following...
354
Is there a way to choose the base font in ME. Text in the Arial Unicode MS which is the default font on my FTVS doesnt show up properly on a...
663
