How to Create RightoLeft Property in Visual Basic - Activex?
Pointing left means whatever tag you put in that field will get written to the active X. Right arrow means the active X will write to whatever tag you put in the field. Both means just that, it reads or writes. if you change the field in the active X it write to your tag and if you change your tag it writes it to the active X.
Eu consegui apontar somente a seta para o lado esquerdo como faço para aportar a seta para o lado direito ou as duas juntos?
Público x as integer
Click_boton
X = datagrid.colums(1).valeu
End sub
Ele aponta pro lado esquerdo como faço para apontar para o lado direito?
Good morning friend, what is happening and following you. I am generating a file in Visual basic as per photo. I put my script behind the screen as photo. I export this file to .OCX to register within factoryTalk. See that it creates both connections according to the 2 variables of the script.
Problem and the following. When I click on the grid fields I want it to set the field value for my Factory variables but it is not doing this with this kind of left arrow. That's why I asked for the arrows, it has to be bidirectional for him to play my grid variables for 2 tags on a supervisory screen.
How do I create the arrows pointing to the right side or the 2 sides can inform me?
Tela DataGrid Scritp - 10.jpg DataGrid Scritp - 10.jpg Supervisorio - 10.jpg
Hello, I've been trying to learn this a while now and still have not found out how this works. I have an Omron CJ2M PLC and an ABB ACS 355 VFD...
237
153
Good morning to all, I have the following issue, I installed everything of intouch including the patch, it is the 2023 version. The...
329
So, I finally got versioin 27 installed on my Windows 10 VM. However, now I can't upload a project from my lab controller. I have the above error...
1,127
Hi all, I have few GB of logged data created by RS View 32 Works, it is all in .DBF format. At the moment, my company wants to shift all data to...
1,445
