FT View SE V5.1- Best way to write list of tags in one PLC to another PLC?
Tanquen
Jul 2014
CA
163
I know they should not be doing this in SCADA but a customer wants to read tags from one PLC, use them on the View SE process screens and also write some of them to another PLC.
Like this every second or so:
PCP\FE_102_ANA_IN_PV == S1\FE_102_ANA_IN_PV
PCP\FE_103_ANA_IN_PV == S1\FE_103_ANA_IN_PV
PCP\FE_104_ANA_IN_PV == S1\FE_104_ANA_IN_PV
I'm looking at Macros and or Events for this. It looks like I can just use an Event but not sure how to trigger it. Also looks like you have to add an expression for each tag. So maybe a macro triggered by the event or better to use VBA somehow?
Also looks like you can import EVENT files but do see a way to export.
CV for DOS files EVD?
Good Evening , I have a Panelview Plus that I need to go back into Config Mode. I understand that if you have a USB keyboard you can press...
2,043
V 10.00.01 Patch 9 I was wanting to make an analog process variable display global object but I guess that is not a good idea. We are doing this...
4,885
According to your experience, what is the best database to use in Datalogs? Historian sucks. A ultra expensive software, a real headache. Too...
1,356
Hi folks, I've been given some help already with PlantPAx which has been much appreciated, I'm looking for a bit more now though please!:)...
2,133
