RS Linx To Excel
Donnchadh
Jun 2002
Ireland
1,004
Hi All
I have set up a OPC server in RS LINX OEM to connected to a
excel spreed sheet. This works fine and I have no problem reading tags from my CLX processor.
The question I have is can I write down to the plc tags.
I would like to be able to read the tag and maybe change the value in the tag.
Thanks for any help
Happy new year to all.:ROFLMAO:
Donnchadh
Yes. You can use DDEPoke in VBA to write values to the PLC.
There is an example in the RSLinx help files:
Code:
Sub Block_Write()
'open dde link: testsol=DDE Topic change this to YOUR topic name
RSIchan = DDEInitiate("RSLinx", "testsol")
'write data thru channel
DDEPoke RSIchan, "N7:30,L5", Range("[RSLINXXL.XLS]DDE_Sheet!B7:B11")
'close dde link
DDETerminate (RSIchan)
End Sub
Then you need an event to call the subroutine, like a command button or whatever you want.
Hi OkiePC
Thanks for that.I palyed around with that today and it works
fine.I just used a command button and its perfect.
Thanks again
Donnchadh
Hi, I'm brand new to the forum and spent some time looking around but could not find an answer to my question. I'm using an excel spreadsheet to...
1,339
Hello! I am trying to help a coworker get access to a company dashboard. It runs on my computer and I have set up similar dashboards myself, so...
2,519
Hello All, I know it is possibile to access data from a PLC directly to excel using a OPC link through RSLinx...
1,753
Good Afternoon , I need to gather some data on a Excel spreadsheet from a CompactLogix PLC. I understand , thru RS Linx as a "go between" ...
3,532
I use dde/OPC to read tag vaule in excel file its working ok when rslinx running NOT as service but when I run rslinx as service I got an error at...
1,948
