DONATE your automation expertise to COVID-19 fight
Delta Tau PMAC expert
My name is Mike Esposito, currently work for Omron Delta Tau. I have 20+ years experience with Delta Tau PMAC motion controllers. I have extensive inventory or legacy controllers as well.
I'm currently working to help a company get an older Black Clawson Winder for making mask material up and running, it has a GE 90-70 PLC with 3 PMAC VME cards. We have it running after about a week of support, all support was possible remotely as well.
Let me know if someone needs help with a PMAC controller.
Best Regards,
mike esposito
804.318.0489
[email protected]
Central Ohio. Extensive familiarity with Allen Bradley processors, HMIs, and SCADA. Can also handle automation direct, mitsubishi, and a variety of packages.
Drop me a message, or email [email protected]
Can easily help remotely, if necessary.
We also have multiple 3D printers (FDM & SLA) and have been printing tape bias makers (4cm and 5cm) for sewers in the area. If you need something printed, we might be able to help. If you need a tape bias to help in making masks, shields, or other things, just let us know.
Area: Tulsa, Oklahoma and surrounding area
(918)607-3366
[email protected]
Experiance:
30+ years experience
GE 90-30 and Rx3i along with Quick Panels
AB SLC500, Control Logix, Compact Logix
RSLogix500
RSLogix5000
FactoryTalk View ME and SE
Temperature, flow, and pressure controllers
Combustion burner systems
Boilers, duct burners, pollution control systems
VFD's
Any kind of electrical or process troubleshooting
Here to help where needed
open time
I am a PLC Programmer / Electrical controls Specialist.I have experience with most Allen Bradley software and some Siemens. I work for a Food Manufacturer and most of my experience is in that field I am generally free After 3 PM and weekends. Please feel free to contact me if you need help.
COVID-19 - We would like to help.
Count me in!
Omoron, AutomationDirect, some GE, miscellaneous HMI's.
Additional the company I work for has a complete machine shop and assembly available to produce and ship mechanical equipment if there is an opportunity.
Northern California.
Steve McMartin
Area: western Wisconsin, Mpls MN.
(715)579-9427
[email protected]
Experience:
20+ years experience in the automation field
Rockwell, RS5_RS500_RS5000
Factory Talk View ME and SE HMI
Siemens PLC
HVAC programming
Boilers
Fanuc Robot training including programming and integration.
VFD, Soft Start.
Low & Hi Voltage wiring and troubleshooting
I am working currently as part of the critical infrastructure but always willing to help out in my free time, if anything is needed please ask.
I'm located west of Portland, Oregon with experience in Siemens, Rockwell and GE PLC's and Rockwell, Cimplicity, Siemens and Wonderware HMI.
Most experienced in Wonderware and Rockwell.
I would be willing to help out. Currently I am in Augusta, Ga.
I have 43 years experience in hardware and software design with:
Allen Bradley( All PLC's, VFD's, Servo's and HMI's)
Siemens step 7(PLC, Vfd's and servos and HMI's) Have not had the opportunity
to use the TIA portal as yet.
Some GE experience with the 9030, 9070 and series 1.
Modicon and a variety of others no longer around.
Visual studio experience
OPC experience
Some experience with Inductive HMI's.
Current availability would be evenings and weekends though that may change soon leaving me with much more free time.
I can be reached by PM here.
COVID-19 help
I'm a controls specialist in Cleveland Ohio with software and experience with Rockwell/AB Logix and FactoryTalk systems. I have PLC5, ControlLogix, and MicroLogix at my facilities. I just finished a couple of big projects, and I'm pretty sure my company would donate my time. If not I have more vacation than I can use. PM me.
I can offer programming and designs for a small PLC system that will make an electric actuator
or pneumatic cylinder pump a manual ventilator to help keep patients breathing. It will have
an HMI screen that will have settings to adjust pump rate for respiration rate and settings
such as how far the electric actuator will pump the manual ventilator (rate control and volume
control).
See these examples: https://www.youtube.com/watch?v=DdQg11QgpXg
https://www.aliexpress.com/item/4000812950490.html?src=google&src=google&albch=shopping&acnt=494-037-6276&isdl=y&slnk=&plac=&mtctp=&albbt=Google_7_shopping&aff_platform=google&aff_short_key=UneMJZVf&&albagn=888888&albcp=1582410664&albag=59754279756&trgt=743612850714&crea=en4000812950490&netw=u&device=c&albpg=743612850714&albpd=en4000812950490&gclid=Cj0KCQjwybD0BRDyARIsACyS8mvxYky4K0tn1fpfON4yCvhE0-wx60N4_RW97_rjEDG7p0i5UbjF3UkaAsXaEALw_wcB&gclsrc=aw.ds
I will write the programs and make the blueprints for this, I will do this all remotely.
The estimated cost of hardware would be approximately anywhere from 1,000 USD to 5,000 USD
Please contact me if you would like my assistance or brainstorming ideas.
PLC/HMI Programmer in SE PA
Rockwell PLC, HMI, and Powerflex drives.
Wonderware Intouch.
Siemens S7 PLC and drives.
Availability is limited, but some weeknights and weekends.
I work for AutomationDirect and live in the North Georgia area. My have an extensive background in Industrial automation and controls and electrical systems. I have been out of the field for a while, but am still up on PLC's and HMI's. Contact me, I'll let you know if I can help or I will try to find someone who can.
Hello Folks,
I am a retired Controls Engineer, located in Phoenix, AZ.
My expertise is primarily with Schneider(Modicon) PLCs, and CTC (Parker) HMIs. I have worked in my career on many types of PLCs and with the proper supporting (programming software) I can work/assist in modifying or troubleshooting just about any type of automation. I am willing and able to provide any help in this field, in the hopes of supporting anyone trying to provide service or support in the CoronaVirus "EXTINCTION".
Sorting through years of 'stuff' (that is the polite word). I have industrial catalogues from 1988, is there someone who collects this stuff or...
2,466
Hi, I had a number of old PLCs and I/O modules following some upgrades. SLC 5/04's 5/05s L32E, L35E, S7-315-2DPs, 314, Does anyone know of...
3,859
Im trying to install a Siemens upgrade license using Automation License Manager v6.0. I clicked D: mistakedly, and now I can not find a way to...
103
I noticed in Rockwell AOIs, they add a BOOL Output parameter at the end of the "Parameters" list of each AOI that carries the same name as the...
112
