Intouch vs PLC rockwell
Le Tri Dung
Nov 2022
A
on intouch i have 1 access name “PLC1”, node name “192.168.3.6”, application name “DASABCIP”, topic name “plc1”, check “suitelink”. Now I want to see the tags in the access name "PLC1", how do I do that? I want to know how it is linked to the tag PLC
ABCIP is a driver application that is running on a computer with IP address 192.168.3.6. Login to that PC and open the System Management Console. Navigate the hierarchy to ABCIP and down to the PLC configuration. Here you will see the PLC IP address and communication configuration.
From the InTouch side, open Window Maker and access the Tagname Dictionary. This will show you all the configured tags. The Item Name field is in the name that will be requested from the PLC.
Ok, thanks
I have a rockwell and intouch PLC program available that connects to that PLC. Now I want to know how the intouch tag and the PLC tag are linked...
2,080
Hi All Predictably, I have a problem making Intouch talk to compactlogix 5380 plc !!! In Intouch I've declared : Access name = Tank_Farm Node...
708
Hi AllN Predictably, I have a problem making Intouch talk to compactlogix 5380 plc !!! In Intouch I've declared : Access name = Tank_Farm Node...
3,166
Hi, we have a Wonderware InTouch (v9.5) application that reads data from several older Compact/ControlLogix PLCs (v.15 firmware) using DASABCIP...
4,786
Hello All, I am using Automation Direct PLCs which are interfaced to communicate with InTouch HMI. The communication is done through modbus using...
2,661
