S7-1500 Wrong partner port
putiss
Sep 2015
Czech Republic
54
Hi all,
I have an issue with S7-1512C cpu. Cpu has error Error on partner - Wrong partner port. Project has 1cpu, 1hmi and some tcp connection. Profinet tpology is not defined. DO you have some tips please?
Thanks in advance
Are you sure there is nothing in Topology View. Only seen this error when something was defined in Topology View, ended up having to add a dummy Ethernet Switch.
Unless it is a big project, maybe backup the project and then create the correct topology. I guess you would use unmanaged Siemens Switches to simulate the non-Siemens stuff. Sorry I can not be much help, not a lot of experience with this stuff.
Solved!
I defined profinet topology between plc and hmi to P2 port of cpu and added new direct cable between cpu and hmi.
Thank you all !
Hello, I have a 1764 1500 LSP Series A that keeps failing with DTL_E_FAIL I/O error. Searching around it seems there's a weird issue specifically...
96
Hi all Trying to remotely connect to a TIA Portal PLC. I can ping it without a problem but can't get my software to connect. I've opened port...
313
Been fighting all morning with a stubborn HMI. It just won´t connect with the plc. attaching from settings. Have i missed anything? Both plc and...
280
Hi there, Maybe I am overthinking this issue, but here is what I have going on. I have a program running for a water valve on a DI system. We...
439
Hello, I am programming in S7-1500, V17. I have some blocks from a drive manufacturer that are not compiling and giving me an error "Invalid...
301
