Studio 5000 UI
JPNoyola
Jul 2019
Nomad
So, I've started working on projects that are using Studio v30 and above. The UI has been changed and while most apparent changes are just aesthetic I really miss stuff like being able to switch through routine tabs with ctrl+pgup/dn and having ctrl+tab switch only between tags, xref, and the like.
Does anyone know if there is any way to change those hotkey mappings? Or the UI in general for that matter? As far as I know I can only change the editor window's colors.
yeah it sucks. its like they are trying to make a a formerly great package(logix 5k and studio 5k) into a terrible one(Proficy).
Wow! I know that Proficy ME has its shortcomings, but I really didn't consider it terrible! Used them both, and had my share of issues with both. All depends on what you are used to, I guess...
I use AHK To make my own keys. It works most of the times, and you can even set it up so it's eligible for non-fullscreen windows.
Hi everyone, I have an issue with installation of Studio 5000 33.00.02 DVD Media disc 2 with View Designer on Windows 11. After installation...
63
Anyone have problems/solutions with Rehosting Studio 5000 to a new computer. Our IT department successfully Rehosted 2 laptops, but the other 2...
114
Hi, I'm quite new to Rockwell PLC and currently trying to implement the following if Sw1 then for i:=1 to 20 by 1 do xEnable := 1...
137
Hello! Hope you are great. I need to make a change in a PLC with ladder logic. I will mount a analog valve and I need to control it in ramp up...
288
I have a few questions about Studio5000. 1. Why is my RA folder so big? its well over 100 GB. 2. How do you delete versions or extra files...
269
