Complex FO network with S7-1200, KTP and IP cameras.
Homer_BL
Feb 2003
252
Hi all!
Is attached configuration correct? Please answer experts/expirienced ONLY.
Do I need a CP card in PC Stations, or use a standard Ethernet port? If I must use CP card, will then Sistore software access IP cameras through CP card?
Best regards and thanks in advance
Yes it's very legacy.. but sometimes it's necessary to use old stuff for fun.. and because it's so much cheaper. Crimson 3.0 had the ability to...
1,643
Hello all, I am fairly new to programming HMI's and am working with Crimson 3.1 for the first time. I am trying to recreate an annunciator of...
6,395
What application in your experience has demanded the most complex PLC program? I suppose I should clarify what manner "complex" I'm asking about...
37
12,613
I have this complex code tag that returns as a string variable. For some reason it returns the two strings with a ?? between them -- not the...
3,532
I have my L5K file imported into my project, and the tags I need in the "available addresses". Is there a way to access my PLC tags in a complex...
2,978
