Siemens TIA Portal V15
paulcamborne
Jun 2007
ellesmere port
Hi.
Does anyone know how I can get the PLC code to display an HMI for the purpose of fault finding, do I need to run a stripped down version of TIA or can I use a soft PLC on an advanced Siemens HMI?
Just an idea at the moment but trying to get a feel for whether its possible.
Cheers
Hi.
Cheers
If the idea is to display PLC code in an HMI for the purpose of diagnostics then the answer is yes. Depending on your version of TIA and HMI, later versions can do panels and RT advanced earlier (TIA 13) can do Professional only.
I've seen this facility before in a custom built SCADA package for marine/military industry and it was great as you could track the logic directly from the value being displayed on the screen by right clicking and following the link to it. It also allowed, if logged in as admin, to change certain parameters as alarm limits or timers that needed tuning and it was really useful.
Although part of it was precisely to protect the technology behind it as no one could actually see the code behind it.
I am currently am in a PLC class and need urgent help on how the ladder logic would be laid out. I understand how to get the traffic lights to...
19
392
Hello, If the date on the license manager of tia Portal has expired, can I still work with it? or is this just to keep the program up to date...
189
Hi everyone I've created an FC that includes the blocks TCON, TDISCON, TSEND and TRCV. This block has to be as generic as possible across...
1,488
Hello, i can find the CPU when searching for it. But when I go Online i just get the icon for "Not compatible" everywhere. I get no additional...
1,085
Hi, I want to initialise some tags on first scan only. As they are related to wall-clock time, I want to do the initialisation when the PLC first...
1,128
