RSLogic Firmware update
Nov 2009
India
116
Hi
I have redundant logic system,L65 CPU. Currently the redundant system is working with Firmware version 13.0
I need to update the firmware for CPU to 16.5
My doubt is, whether will the update of firmware deletes the program and communication settings which was working as in v13.0?
I guess update of firmware will not cause program and communication settings to erase, anyway i need suggestion pls.........
First, you need to pay attention to details: L65 controller has minimum revision 17 and currently not supported by any redundancy releases.
If your controller is L55 then highest you can get is redundancy v15.
So identify your system first.
Next, you will have to upgrade ALL modules in primary/secondary chassis, not just your controller
Firmware upgrade WILL erase your program, that is why there is a special redundancy firmware upgrade procedure defined in release notes and redundancy user manual.
how to delete password protection from rs logic500 (plc is micrologic 1400) i kinow the plc but i want to remove password protection. what is the...
1,617
Hi I am trying to add a AC Servo Linear Actuator, I know that i have to add a axis, but when i am trying to add the motor with catalog number. In...
2,227
I logged on to one of my machines today to try to communicate with the machine (Micrologix 1000) and there are only two plc's on the network, but...
2,122
Hye Does anyone here have the V17 copy. Mind to share? I downloaded but got error during install.
1,856
Hi All, I have compact logix L32 PLC and I want to establish connection between Festo CPX-F32 Valve Island over Ethernet I/P network. The Festo...
2,384
