RSLOGIX 5000- can not access devicenet modules
Void
Supporting Member
Aug 2022
Australia
Hi Guys,
I am using rslogix 5000 at work and we have different zones with different PLCs and some of them have devicnet scanners as well which are connected with the controller. Recently, we could not connect to the dnet scanners from the rslinx, all the scanners in the list have crossed sign on them. everything is working and online but we can not access them from the software. Please see attached picture. thanks guys.
If your backplane communication is working, but RSLinx isn't able to identify devices successfully, this seems like an RSLinx issue.
Have you tried to delete the Harmony files for RSLinx? I would give that a go. Instructions are here: https://rockwellautomation.custhelp.com/app/answers/answer_view/a_id/769010/loc/en_US#__highlight
QA29673, access level: Everyone
Summary
RSLinx Classic: Clearing cache by deleting Harmony files
Question
How can I delete Harmony files that have become corrupted?
What to do when RSLinx stop communication or showing yellow question marks even EDS files are present?
Environment
RSLinx Classic - all versions
Answer
Download video: MP4 format
You can delete Harmony files if they are corrupt or on a regularly scheduled basis. They are cache files of RSLinx and will be automatically recreated when RSLinx Classic is reopened. For more information about the Harmony files, please refer to QA165 - Description of Harmony.
Warning: When RSLinx Classic is performing as a OPC/DDE Server for an application, delete the Harmony files only when the application is not in operation.
You may want to backup the configuration of the drivers if you have many drivers or various configurations. To back up the current driver configuration:
Go to Start--> Programs--> Rockwell Software--> RSLinx--> RSLinx Classic Backup Restore Utility.
Select Backup.
Enter a filename and a location, and click Save.
After you are finished deleting the Harmony Files, you will need to Re-Start RSLinx
Select Restore. (If you don’t restart RSLinx before you perform the Restore, you will receive an error).
You can delete the Harmony files with 2 methods: Automatic and Manual.
Automatic method
RSLinx Classic version 3.90 or higher with valid activation
In RSLinx Classic go to File--> Compact Harmony.
RSLinx Classic version 3.81 or lower
Run the Rslinxcachedelete.bat file. It will stop the RSLinx Classic service, delete the Harmony files and then restart the RSLinx Classic service.
Manual method
Close all software including RSLinx Classic. If RSLinx is running as a service, switch to run as an application by following QA406 - RSLinx Classic: How to run as an Application or as a Service?
Open Windows Explorer and go to
For 32 bit Systems, C:\Program Files\Rockwell Software\RSCommon
For 64 bit Systems, C:\Program Files (x86)\Rockwell Software\RSCommon
Delete Harmony.hrc and Harmony.rsh (you may have Harmony instead of Harmony.rsh). Do not delete HRMYUI.DLL
If you cannot delete the Harmony files, stop the Harmony service from Start--> Control Panel --> Administrative tools --> Services or reboot your computer
If you have a Windows 64 bit system you may only have 1 harmony file.
Change it back to run as a service, and restart the computer if necessary.
thanks for the reply, i did delete the harmonix file file but after the pc restart, those file would come again and same issue with the network.
Hi guys, I am currently working with the setup: Rslogix 5000 + CompactLogix L24ER-QB1B controller + 1769 Analog IF8 module. For what i know...
3,850
Hi, One of our clients is wanting to view PLC Code offline and online to diagnose/fault find. The problem is, he is the type of guy who will...
17,847
I am working in RSLogix 5000 version 17, 18, 19 and I have several tags: alias DINT: Pump_1_start Pump_2_start . . Pump_X_start Base DINT[6]...
4,499
147
