ControlLogix Online Indicators
At least one of the I/O connections is not available. This, at least in this configuration, is not enough to prevent it going into 'Run' mode or causing a fault, but the equipment may not operate fully. Look at the status icons in the I/O configuration for the problem items.
That can also happen if you have a communications module listed in the I/O tree, with nothing connected to it in the I/O tree. The usual culprit here is the Ethernet module. There is no reason to list it in the I/O tree unless you are using it for remote I/O or produced/consumed tags.
If it is listed, with no partner, it will give the blinky I/O light warning.
The I/O light will also flash if you have Consumed tags that are not being consumed (e.g. the producer is not there, or there is a configuration error).
Look in the I/O Configuration area of the controller organiser, and follow the warning triangles to the module that is in error, double-click it to bring up the Properties dialog, then choose the "Connection" tab. On there you will see what the fault is.
I've never seen that happen... Which comms module(s) is this relevant to?
I've just tried it with an ENBT in the configuration, with no children, and no I/O errors are present.
If there is a 1756-DHRIO included in the I/O tree and is used only for DH+ it will cause the I/O light to blink.
Does anyone know of a way to detect if someone is online with the controller in ControlLogix (from logic) I'm thinking that maybe there is a CIP...
377
Are any of you guys out there aware of a consolidated list of I/O cards that can be replaced online? We just replaced a 1756-IF16 card while the...
1,518
Hi I'm trying to change the scale in a analog Input module in the module while online. I got a warning saying something like Module changes could...
2,056
Good Afternoon, I should know the answer to this . I have a 1756- 4-20 ma input card with spare inputs .I would like to add a new Analog...
1,848
Is it true that you don't get the green True/False bars in "Online" mode on every element type? For example, the GTEQ or NEQ block: it doesn't...
3,463
