I have problems when trying rslinx and micrologix 1500
gemedina31
Nov 2017
Cali
Regards,
I have never had any problems communicating through rslinx with the AB plcs, but I have run into a serious problem, which is that I have not been able to access a Micrologic 1500 using the original 1761 CBL PM02 serial cable. I tested if it is the cable that is bad, but as I say with other PLCs I can access autoconfiguration with DF1.
The problem is that, when doing autoconfig in DF1, it does not detect the PLC. I called the person who programmed the ML1500 and communicated very easily, but I noticed that he did not do it with autoconfiguration as is normally done and I inferred that the man somehow blocked the communication with the controller to not allow access to his program. Is this possible to do?. Can i decipher it? How do I do it?
I await the prompt response of a good Samaritan.
Thank you.
I have been having problems restoring application in FT ME from a runtime (.mer) in the latest version of FT ME (v6.10). The displays have...
30
13,372
Anyone have problems/solutions with Rehosting Studio 5000 to a new computer. Our IT department successfully Rehosted 2 laptops, but the other 2...
119
Hello. I appreciate the insights here and the willingness to share. I've got a lot of Rockwell experience, but my Siemens experience is...
175
Currently a student, so somewhat new to this. But working with an AB 2080-LC50-24QWB, CCW version 21.01.00. CCW will connect okay to the Micro850...
290
