rejoe.koshy
Hi guys,
I am facing an issue with a motor which is encountering a recurring failure of its mounting stud(its a flange mounted motor), which is found to be broken.
It is a dual speed motor ( dual pole windings 8p/2p) & there was issue with the controller which switches the motor from one speed to another & hence I by passed it.I have noticed that the issue of motor stud failure surfaced after I had bypassed the controller.
I am not able to understand the real cause behind this phenomena.Does the frame or the stator windings experience any force at start up which is causing this issue?
Pls help.
Pls help.
