FTView ME address bit of Int
blperkins
Jan 2006
minnesota
73
Hello folks.
I migrated a simple Micrologix PLC program to run on a Compactlogix.
As expected the Compactlogix program has tags that are named B3, N7, Etc.
An existing panelview plus 7 (FTview ME 11.0) used the Micrologix B3:x/y addresses for buttons and lights.
I changed the communications to look at the new Compactlogix and I can browse tags in the PLC. But, I can not get to the bit level of the B3 tags.
I did try selecting the B3[3] tag and then adding the ".1" to the end but the run time complained about that.
Can the Panelview Plus 7 not use the individual bits in a word? or am I missing something?
Not a FTV ME expert and I couldn't find where I tryed to use a bit of a word in my other FTV ME projects. This I know, when you did the conversion all of your bit addresses should have been given tag names like B3_0_0 that are of Boolean data types. You should be able to use those tag names in your HMI Program like the old B3:0/0 you had before.
When I have had to address to the bit level, I have used an AND bitwise operator in the Expression Editor.
e.g.
bit 0 : [tagname} & 1 (2^0)
bit 1 : [tagname} & 2 (2^1)
bit 2 : [tagname} & 4 (2^2)
....etc....
bit 15 : [tagname} & 32768 (2^15)
Clunky, but works ....
Hii all Created hmi screens in ft view ME version. rev 6.00. During testing the application. I have found all the screens are working good But in...
2,052
I am creating a global object in FTView SE 13. I want to have a string read from the PLC and display (in this case the tagname). So lets say...
167
I want to set user security level based on the value of a tag in my PLC called "ActiveUser". That tag will contain the A-P code which we use for...
211
Hi All, we've recently upgraded from FTView SE v10 to v12. Since the upgrade we've been having a problem where the HMI is slow to update tags in...
87
Hi, I have an issue accessing tags in 3 of my plcs'. When I go to select a tag there is no folder drop down as can be seen in the photo. Any...
86
