[Proficy Machine Edition 8.6] Moving average instruction not available
defcon.klaxon
Feb 2015
Far NorCal
616
Hi all,
I'm trying to set up a moving average in PME 8.6 and apparently there is such an instruction (MAVG) but when I try to insert it into an FBD program block, it's not in the list despite being in the Help File documentation.
Wondering if anyone can help? Thanks!
What project template did you use when you started the project? I believe you need to use the Proficy Process Systems Rx3i template, and not the PAC Systems Rx3i template.
I used the GE Intelligent Platforms PACSystems RX3i. Geez, if this is true it's just one more reason why I hate GE.
You may be able to create a new Proficy Process Systems Rx3i target in your existing project and copy any work you've already done to it.
I was messing around, and apparently if you open the Toolchest, MAVG is there. What I found that worked was I dragged and dropped the MAVG into the Program Blocks, then created a new variable (UDFB). From there, I could put the instruction into an FBD block and configure.
Thanks for the help!
I'm getting frustrated creating arrays of variables in Machine edition. I need to make 2 variable arrays that are 102x2 in size, with varying...
105
Hi, I am still a beginner with PLCs and I have never worked with GE PLCs before so looking for some help. I am using GE Proficy Machine Edition...
1,372
I am trying to download version 9.8 of G.E.'s proficy machine edition, does anyone have a link to a download site?
5,115
Need to learn a few more tricks in Proficy Machine Edition. I don't use it often, but one of the first things I usually do when getting into a new...
1,012
I have a GEFanuc plc 90-30 that has dumped it's program and IP. The tool in PAC for setting a temporary IP is not available. The Offline Commands...
2,019
