displaying data stored in a compactlogix to a panleview
Jul 2018
Rogersville
Hello my first time posting so hope i do not confuse you guys. I am wanting to store data from my vibration/Temp sensors that my PLC is already reading and scaling and displaying on my panelview plus 1000. and then be able to look at the old reading on a display.
Welcome to the PLCTalk forum community !
Are these data values being displayed on a Trend object, or as numeric indicators, or as something else ?
How far back in time, and by how many intervals, do you want the operator to be able to go ?
This might be as simple as putting data periodically into a FIFO or other array mechanism, or it might be complex (or impossible; the PanelView Plus trending feature is weak compared to modern SQL based stuff).
Hello MR Roach thanks for the welcome. We want to be able to go back 5 day with a record every hour. I am trending the info now and have it in numeric indicators as well
Panelview Data Log and Trend
In the Panelview Plus Factory Talk View ME Studio developer...
...Create a Data Log Model with your PLC tags and desired sample rate
… add up all of the data points (tags x samples x duration) set the data log model to total tags
….in the start up configuration, add the data log model to start at power up
… create a trend object on a panelview display
that is all there is to it! :)
I "think' FTME only allows one datalog to run at a time. Can you add your tags to the currently running data log?
HTH
Hey folks! I've gotten an idea in my head and I'm wondering if anyone can help - and my title is terrible because I'm not good at articulating...
1,026
Looking to display data from the Factory Talk historian SE 4.0 on a screen in Factory Talk SE 8.1. Was wondering if anyone has run into this...
1,579
Hello Everyone, I am new to this forum and also new to PLC programming so please do bear with me. I have a Data Logging PC where i am using FT...
2,134
I want to display the results from a SQL SELECT statement inside intouch. Looking for some kind of example as the SQL Access Manager doc is not...
11,640
I have to bid on a project that displays some shift data on a 70" hdmi tv. I've seen these before but I've lived a sheltered life and haven't been...
7,087
