Micro800 Time to String in usable format
SME
Sep 2016
Mildura
Hello Guys,
Im struggling to find an easy way (Hoping for a UDFB) or simple alternative
to take a TIME value (time remaining from a timer) and put in the middle of STRING text to send as an SMS.
I have got the sms and the inserting string valve into a string sorted,
However I cant insert time as it is into a string, and everything i convert it to is in an unusable format
I found the hard way, To convert to a DINT then /1000 to get seconds, then /60 for Min, then /60 for hours
Then its about another 6 rungs of code to get into a usable format to insert as a string
however I have to do a lot of these and its a LOT of code and memory
There must be an easier way someone has come up with?
Any ideas
Shaun
Are you using the Micro800 to send the SMS or will a different device be what actually sends the sms message?
Have you tried the Any to String function block that Rockwell provides?
Hi Damica1
Yes a Micro820
From NHP you can buy in a kit comes with
-Micro 820
-Power supply
-2080-SERIALISOL (Serial plug in module)
The Micro comes pre-programed with some code to get you started
-SmartSAM4T 3G/4G Modem
-Antenna
I cant use the any-to-string
It just spits out an unusable figure
RTC_Read function block will return the "Date/Time" into UINT. Now just convert each output into a string with "any to string" function then merge into a single string.
This should work!
This is not done or tested but I think it may help with getting you what you need.
Localvars picture shows the local variable that I used. The ladder shows how I might flow the program.
Once I got everything working as I needed I would create a UDFB so that all I had to do was to drop on a rung input a couple of variable and the end result is at hand.
Hope this helps, have a great day.
Hi David,
Thank you for that, looks simpler than what i came up with I wish i had have seen this first. Thanks for the reply, I might have a play with this new info!
However I couldn't use for a timer value it wouldn't let me.
Have a look at my UDFB if you want
Cheers
https://drive.google.com/drive/folders/1Yy-G970mM4twCHF378W454Jl-2kQNnMK?usp=sharing
view
view
Hi All, I am having trouble converting a real to string and keep it to 2 decimal places. I'm sure its a simple solution. Any help is appreciated
262
My company built a small test machine using a Micro800 PLC and CCW software. We chose the Micro800 because the machine is very simple. We are...
135
Hi, Is there a way to set the IP of a micro dynamically, based on a variable value.?
155
Anyone use the newer 2080-L50E or L70E with 1734 Point IO yet? I have a customer asking for a setup and I have not found anyone that has done...
366
Is there a way to download the program to a Rockwell Micro810 without using the Rockwell CCW application?
717
